Oil in my bellows
Handchops
Yeah I'm new to this just pulled off my out drive and I see oil in my bellows. I'm guessing that's not a good thing?
Re: Oil in my bellows
Nope,... That means the big seal on the input shaft is Leakin',....
TheHunter990
That must be outdrive oil in the bellows, you need to replace input shaft seal. I'd try get it pressure/vacuum tested after seal replacement, so you know its good.
You'll need bellows adhesive to reinstall drive. I don't think you can get engine oil in the bellows, (well the exhuast bellows you could)
Handchops
Thanks for the info. The bellows all look pretty good, but at this point should I change them or at least the main bellows? Not sure if the oil sitting in there may shorten the life of the rubber? Will I need special tools? Thanks!
