boatinrocks
Thread starter- Joined
- Jul 19, 2010
- 2
Hey there!
I'm quite new to boating and am definitely loving it but am in dire need of some advice from some experts.
Imagine you had a Johnson 20HP 2-stroke outboard motor and a 10 gallon (40Litre) external tank. If you filled the tank with the proper oil:gas ratio and then,when your tank was at the 3/4 mark (several days later), someone topped it off with straight gas and no oil, what would happen to your motor? Would diluting the oil by that much cause severe permanent damage? Or would you need to have a much weaker concentration of oil to actually cause damage?
Secondly, if damage were to happen, would it happen within moments of adding the gas, or would it occur much later as the initial gas/oil mixture was consumed?
Thank you for taking the time to help me out.
