RedRustler
Thread starter- Joined
- Feb 19, 2005
- 47
ok i have ohm tested secondary coils,pulsar's,and i think the wires for the pulsar's coming out of the CDI<br />All test's were performed with motor and ignition off.<br /><br />Pulsar's<br />W/G = 200.9<br />W/R = 205.9<br />W/B = 204.2<br /><br />spark plug cap's / coil's<br />#1 = 3.453<br />#2 = 3.487<br />#3 = 3.473<br /><br />pulsar wire's from CDI<br />W/G = 9.97<br />W/R = 9.90<br />W/B = 9.90<br /><br />Do these readings seem to be accurate?<br /><br />Yesterday i pulled all of the electrical connector's cleaned and dieelec. greased all plus ground's. I also last night pulled the #3 carb disassembled and soaked and blew out the carb.<br /><br />I put every thing back together today and took the boat to a canal to water test it me,wife,son<br />in the boat while takin off the motor sputter's a little which in my experience all 2 stroke does that. and while running i dont get that cutting on and off that i was feeling while running at 5100 rpm so i guess the mystery is solved.<br /><br />Wihile cleaning the connectors i found that a wire coming from cdi to #1 coil was a little coroded and some green krap in the connection. <br />but after cleaning everything and the carb agian i really dont know what the real problem was.<br />O-well at least it seems to be running correctly for now
