redneckpunk
- Nov 19, 2008
- 130
Some quick background. Boat is a 1993 that has had an older merc o/b mounted on the stern. No serial # but believe its about a '77 1150.
Problem is it appears the '93 throttle was used and the neutral safety switch was bypassed. I have 5 wires coming from throttle housing. 3 are for power trim. However, coming out the back of the housing are two blk wires with yellow stripes that have been cut. I traced the wires into the housing and found both go to the safety switch. I've checked the wiring harness from the motor to the counsel and dont see anywhere that those wires might tie in. The only other blk/ylw wires I have run between the ignition/key switch to the "kill switch".
So I guess my question is, how and where can I re-attach those safety switch wires in combo with the kill switch so there is no chance of an accidental starting in gear? I used the boat all last summer after purchasing it and never realized the issue as I have been around boats my entire life and the last thing I do before turning the key is check that its out of gear. But theres no guarantee that I will always be at the helm.
Thanks in advance
~RNP
Thanks in advance
~RNP
