Greetings. I am at lost with this motor 2003 nissan 18hp fourstroke
I am having this issue on the oil pressure
I have replaced the sensor and the oil pump
Tested oil pressure with a mechanical gauge and it seems to have below 4 psi at idle & would bump up if given a little bit of throttle. Anyone has similar issue that found a solution? Thank you.
