Not starting
jasnatno1
Hi All
Looking for some help please !
I have a 2004 Rinker with a 6.2 MPI and I did a stupid thing....installed the battery terminals incorrectly. Now I have no iginiton or stereo or blower. All other electrical stuff like lights etc....work but will not start or even turn over. Don't even hear the fuel pump or any relay cut in.
Please help
Thanks
Bt Doctur
Re: Not starting
Check the 50A breaker mounted on the engine,
jasnatno1
Re: Not starting
I did but is it possible that can be defective or blew it when I installed the battery wrong. Would u know how to test it to see if its working
Thanks
Bt Doctur
Re: Not starting
You can use a test light or voltmeter to see if batterey voltage is
on each side
Don S
Re: Not starting
I sure hope you are lucky with what was turned off and what was on when you hooked it up wrong, because that fuse blows from being shorted to ground. Reverse polarity is a whole new ballgame. Computeres (aka ECM's) don't like reverse polarity.
