FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i had taken plug off top cylinder it wanted to die<took it off bottom nothin happened,but there was plenty of spark going from plug wire to plug,when i had it off.just got into boating so im nt familiar.some say coil is bad and others say ok.??
no i didnt check right after bt i noticed before it is wet .unlike top one it was dry..i will recheck in morning to be sure.i hv tested the fuel pump twice and it seems to be running fine.just incase u asked.lol
as High Trim suggested....a compression test is in order first...then on to the ignition side....start with compression as no amount of swappin' an prayin' will help w/o sufficent compression
