FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
04 Yam F225 Charges 14.0 Volts For About 2 Hours Of Running Then Drops To 11.10 Volts If I Turn Off And Let It Cool Down It Starts To Charge Again For A Period Of Time
post the model number and the seriel number. look at the rugulators,its mounted on the pan on the port side.
tell me the color of the 4 big connectors.
bummer
you already have the latest regulator assy.
now its time to carefully inspect the battery cables, if they are good your either loosing stator lighting coil voltage or the regulator rectifier is going south.
the regulator/rectifier is actually located behind the electrical panal, the part I was asking you to describe is the driver assy.
some models had an update that changed the driver and rectifier assy, yours already has it.
make sure the tell tale is working as the regulator/rectifier assy is water cooled by the telltale water.
