Normal wear or Cav Burn...take a look!
Purduebarry
Need a new blade, this one has been re-worked a bit and will use it for a back-up. I was looking at the Michigan Wheel 3-blade Vortex or the Turning point Hustler. What do you think of the prop on the boat now? Normal wear or cav burn? I want a bit more cupping than the OEM version I have now.<br /><br />
WillyBWright
Re: Normal wear or Cav Burn...take a look!
More likely poor pre-painting preparation.
walleyehed
You don't say what prop that is...looks like a cobra, so I'm guessing a 14-1/2X19???<br />Looks like the diffuser ring is gone too.<br />Tell us a bit more about it and we can go from there.
Purduebarry
It is a Michigan Wheel, Michigan Match 14.5" x 19. RPM at WOT is okay, It's a Cobra alright.<br /><br />The diffuser ring is there but a bit banged up. <br /><br />I was looking at the Vortex for a bit more cupping than the MW MAtch. Pound for pound these props seem very similar. <br /><br />I also considered the TP Hustler. They claim the Hustler has SS performance caracteristics...but my 5 year old thinks he is a stand up comic so claims are just that. The TP is only avail. in 14 1/4". <br /><br />I just thought the pic would help determine what is going on back there. <br /><br />The prop is as old as the boat (18 yrs). Local prop shop said bring it in and they can "re-work it" for about $60 bucks. Claim it will be balanced and good as new, will add cupping if desired. I want a new prop and keep this as a back up, as is.<br /><br />Your thoughts?
