- Jul 23, 2011
- 52,563
you will need to run a tap in it if it has sat for a bit of time. rust has developed on the threads. to run the tap in, you will need to grind down the tip as the tap will most likely bottom out on the cylinder liner.
you will need to measure your current cable, then buy a replacement cable
you will need your serial number for your drive for parts.
