No voltage to gauges when engine is running.
Bcookson
2002 Evinrude 200 ficht, when the key is turned to run the sytems check monitor and warning horn activate and go off, the instruments in the dash activate then go off when the key is turned to start the engine. The engine starts immediately but the gauges do not respond. Any ideas?
cr2k
Re: No voltage to gauges when engine is running.
1. bad key switch
2. fuse under dash
3. fuse on motor harness
