No telltale water 15rl75c
hope3351
Hi I hope you can help me with this. I have a 1975 Johnson 15 horsepower its not showing any tell-tale water. I put in a complete new water pump the pin is where it the impeller is turning the right direction and I have now changed up the thermostat. Well the lower unit was off and the thermostat was out I force water up the brass tube it came out through the thermostat opening it did not come out through the telltale hole and it will not come out to the brass tube. I put a new thermostat in and close that up. And ran water up the brass tube. It will still not come out the telltale hole. If I spray water into the telltale hole it comes out around the brass tube but doesn't seem to come out through the brass tube. Any help that I could get would be greatly appreciated. Thank you
AlTn
sounds like you've got a clog in the tube, probably at that elbow that comes out of the block....anything flexible you can run up the telltale hose will probably clear it...compressed air may work as well....the telltale water flow should begin before the block fills with water in those models, so if you have water coming out the thermostat housing then the block and head will have filled with water
kbait
That motor has no telltale 'pee stream'. (Not 'till '77). Some cooling water will spray out the exhaust relief port in the back of the exhaust housing. Water only sprays out when motor is running, as it's blown out by exhaust pressure. Also, water from that port must first pass through thermostat, so very little, or no water will come out until motor warms enough to open thermostat. Forcing water up the water tube won''t make spray.
Run motor in lake, or barrel deep enough to submerge pump, and check head temp w/finger near plug base. If it gets too hot to keep your finger theire for a few seconds, you are overheating.
Good luck!
hope3351
Thank you for your help. I'll see what I can do when I get a bit of time. I tried to run .90 weed eater line in the TT hole but it only went about two inches then began folding.
