Hi I hope you can help me with this. I have a 1975 Johnson 15 horsepower its not showing any tell-tale water. I put in a complete new water pump the pin is where it the impeller is turning the right direction and I have now changed up the thermostat. Well the lower unit was off and the thermostat was out I force water up the brass tube it came out through the thermostat opening it did not come out through the telltale hole and it will not come out to the brass tube. I put a new thermostat in and close that up. And ran water up the brass tube. It will still not come out the telltale hole. If I spray water into the telltale hole it comes out around the brass tube but doesn't seem to come out through the brass tube. Any help that I could get would be greatly appreciated. Thank you
