no tach on Johnson 40 HP
joeski222
I have a Johnson 40 HP and lost the tach over the weekend. Where do I start?
joeski222
does anyone have a write up of how to check the stator and voltage regulator? it is a 1993 Johnson 40 HP tj40eletb
gm280
:welcome: aboard joeski222. Nice having you join us...
If your engine presently cranks up and runs, take a volt meter to the battery and see if the voltage goes up after cranking. If so, then your rectifier and regulator (if you have one) are good. If the voltage doesn't go up after the engine is running then you either have a bad rectifier and or regulator or even a stator. And if you know how to use a meter, you can check the stator wires disconnected from the rectifier to see if it is shorted or even shorted to ground using the resistance scale of the meter. Either condition means the stator is toast... And if you do know how to use such a meter, you can test the forward and reverse resistance readings on the rectifier as well. Any reading the is absolutely shorted is bad and any reading with an absolute open is bad. So make those tests and report back here so we can guide you to the part or parts that are bad...
joeski222
The day it stopped I was out on a longer than normal ride. I usually just motor across the lake then use the trolling motor for a couple of hours while fishing and then motor back, but this day I was taken the wife on a tour of the lake and running the motor the whole time. Everything seems to check out when I was testing the resistance in the garage and decided to start it up and everything was working again. Must be something that fails when it gets hot. For now it is recharging and the tach is working. My assumption that something is on its way out and I will be revisiting this again later. Thanks for your help. When it breaks for good I will let you all know.
gm280
Maybe you can head off a problem by checking and cleaning the electrical contacts on you boat. Remove the contacts one at a time, clean back to shiny metal and reconnect. Do that to each terminals and you will probably not have anymore issues... JMHO!
F_R
Honorary Supreme Mariner
Battery cable connections!! Remove them and clean everything shiny bright and reassemble making sure everything is tight. Rectifiers don't "almost" die. They are either good or bad. Since yours is working now, it is good. But it won't be for long if your battery connections are bad--the #1 killer of rectifiers.
