The day it stopped I was out on a longer than normal ride. I usually just motor across the lake then use the trolling motor for a couple of hours while fishing and then motor back, but this day I was taken the wife on a tour of the lake and running the motor the whole time. Everything seems to check out when I was testing the resistance in the garage and decided to start it up and everything was working again. Must be something that fails when it gets hot. For now it is recharging and the tach is working. My assumption that something is on its way out and I will be revisiting this again later. Thanks for your help. When it breaks for good I will let you all know.
