FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
my 1993 johnson will not run at high rpm, with attempting to obtain speed the rpms start falling until i pull back on the throttle,then open again. the carbs have been rebuilt, linkage has been adjusted, new fuel pump,fuel filter.
you have a 1993 WHAT??? did you remove the all the jets and clean them? have you check timing, have you check compression and spark? did you do linc n sinc as directed in the OEM Johnson manual?
the motor is a 50 h.p., yes the carbs have been rebuilt, linkage has been adiusted per the book, the v.r.o. has been replaced. before the v.r.o. was replaced the problem was worse. at that time if i pushed the primer button the boat would pickup speed.
Does the motor pick up speed now, if you activate the primer? If so it is a carb or other fuel problem. If not, your high speed windng on the stator could be bad. You might ohm it out.
i did not try the primer again, iam sure the carbs are ok, what i do not understand is why backing off the throttle helps for a few moments and the motor performs ok at low speed. not sure which stator was referenced to?
read ethanol, carb rebuilding, if you did not remove the jets and use rebuild kits you wasted your time. http://forums.iboats.com/showthread.php?t=299680 that is a great motor, when properly tuned. have you check spark and compression?
carbs were completely disassembled,all pieces were cleaned, compressed air was used to blow out passeges, kits were used along with new floats, float levels and drop are as per spec.
