No Spark???
stump6469
1997 E-Rude 225 Looper, (ALL NEW ELECTRONICS) went to start it up today and no spark, started TS and found that if I disconnected the ground (Black wire) at the CDI hold down bolt. It would fire but stop as soon as I returned the key to run position. Disconnected shift switch, no change. Checked wires at ignition switch, all good.
What else do I need to check?
Bosunsmate
Check for a ground somewhere along its length and also check for faulty key switch
Bosunsmate
The Black wire, it is a ground?
Nope but if it grounds out to something then it will put ground to the motor which stops it. Check using a $10 digital meter that it isnt shorting to ground along its route. It may of frayed at some point, ive seen that happen
