FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
To check stator, trigger, switch box you'll need a voltmeter with peak hold and a DVA (voltage divider) AND cdi ignition troubleshooting guide.
cdielectronics.com Technical Support menu, Troubleshooting Support will get you there.
J
The troubleshooting guide said if you get spark after unhooking rectifier then to replace rectifier and I am getting some spark now , but wasnt sure should the engine start without the rectifier hooked up ?
went to marine parts store and told them i wanted rectifier for a 1993 mariner 50hp he brought out alot smaller square with three posts i thought it was bigger square with circuit board and five wires on it he said no that is your regulator i do no not see the smaller rectifier anywhere on the motor, he said according to serial num. that is the only rectifier, but my repair man. says the five wire one i have is a regulator/rectifier . that would explain why it was $100 cheaper than i thought. any suggestions ?
