No spark with a tester but spark at the plug ????
gm280
So I replaced the negative connection at the power head. Sounds like it's turning a little faster but the battery discharges kinda fast. Also I got to looking at my solenoid. Should it be grounded straight to the block ? It's connected to a black wire on the big red connector harness. Otherwise I'm gonna start looking into my starter.....
rodknee1231, not necessarily with the starter solenoid. On some engines the starter solenoid goes through a neutral safety switch to ground so you can't crank in anything but neutral. So don't assume anything unless you have the factory shop manual in from of you for your engine. Just saying.
rodknee1231
I have the factory wire diagram it has that black wire coming from the red connector grounded to the power head and it has the ground from the solenoid also grounded to the power head on mine that black wire from the red connector goes directly to the solenoid so it may be trying to ground through the body of the solenoid and not​ doing a great job but idk it may not make a difference
rodknee1231
Ok so I'm still at a loss I'm gonna try to check my key switch. This motor is cranking dang fast to not produce a spark over a gap tester. I've replaced ground connections on the motor. The kill wire is disconnected.
rodknee1231
Ok so I farted around a little more and put on an inline tester and pull out the spark plug and held it against the head. I jumped the solenoid to start it and noticed there is a spark arcing from the plug wire the the outside housing. So that again is leading me to a bad ground any suggestions
oldboat1
There are a number of ground wires shown in the ignition system and cylinder/crankcase diagrams -- Crowleys not quite as descriptive, but the ones at marine engine may help locate them (maybe BRP site). I would make sure ground wires are there, and connections are clean and tight.
rodknee1231
Everything is in place I'll just have to rerun enerything. I just re did the main ground wire to the block so I'm not sure why it's trying to take another route back to the battery other than through the block ?
rodknee1231
Someone please help I'm at a loss here I connected the coil ground wire directly to the ground wire going to o the battery. Go nothing. Now I have 0 spark anywhere possibly because the battery is getting a little low idk. I accidentally touched the ground wire to the positive wire on the solenoid hopefully I didn't fry anything. All the coils have resistance as they should. It seems to be cranking at a decent speed. Maybe my stator is bad ?
oldboat1
Replaced the power pack -- assume you didn't have the shock issue before that(?) There's an insulator that is part of the p.p. assembly. Is that correctly in place? Also a ground strap there....
rodknee1231
Insulator? The front cover ? And yes the ground wire in place for the power pack. Would a bad batter do this? Maybe not enough amps to crank it fast enough?
rodknee1231
Also haven't been shocked sent that one time but if I have a plug wire close to the outside housing it will arc.
rodknee1231
48, 49, 50, and the ground strap (36): http://www.iboats.com/Ignition-System/dm/*******.793303938--**********.156345661--view_id.1553506
Try another battery, or jumping from your car battery.
I don't have the insulator and cover on I don't see any arcing on the pp didn't think it would matter. However I only have the rubber piece and the plastic piece this diagram shows 3 pieces. I only got the 2 from cdi when I ordered the pp. I'm guessing it's just how theirs is.
oldboat1
rubber piece would be the insulator. ground strap? (presumably would need to put that back in place).
rodknee1231
Ground strap is in place. I'm gonna get the battery tested. To rule that out. It discharges kinda quick
rodknee1231
So the battery checkw out which says I most likely have enough cranking speed. Coils are new pp was just tested at cdi last year. Unless my ground connecten at the battery is bad which it looked fine. I'm at a loss. And now I have 0 spark no matter what I do.
gm280
WOW rodknee, I hate to hear you are up against a wall now. If I were there I could test things and try to find the problem, but it is hard trouble shooting via a thread.
I will say that with no spark anywhere, you have to look at what feeds the spark coils as a place to start. Don't give up. The problem is there and you need to start over with testing tings again. Because something is being over looked. Never, and I do mean never, assume any part or system is good until you prove it to be good. And that goes for even new parts and all wires. JMHO :sorry:
oldboat1
When you changed out coils, did you use 7mm solid core wires (not automotive type). As I think some assembly was required, check the spring connectors in the boots. Spike needs to contact the wire core.
rodknee1231
Yes I checked their connection with a multi meter testing the resistance.
