gm280
- Jun 26, 2011
- 14,605
So I replaced the negative connection at the power head. Sounds like it's turning a little faster but the battery discharges kinda fast. Also I got to looking at my solenoid. Should it be grounded straight to the block ? It's connected to a black wire on the big red connector harness. Otherwise I'm gonna start looking into my starter.....
rodknee1231, not necessarily with the starter solenoid. On some engines the starter solenoid goes through a neutral safety switch to ground so you can't crank in anything but neutral. So don't assume anything unless you have the factory shop manual in from of you for your engine. Just saying.
