ctravis595
Thread starter- Joined
- May 10, 2013
- 50
With a spark tester I am getting no spark on the two starboard cylinders. engine runs but is hard to start and boat never gets to full speed
Switched power packs, no change
Switched ignition coils, no change
Found a bad rectifier, replaced it with no change
Spark plugs are new, I also double checked my ignition wires
According to this video, I should get 1.4 ohms between the two yellow wires from my STATOR
https://www.youtube.com/watch?v=xD7jsX86orU
I get 0 ohms
I'm believing my stator OR my timer base is bad
I don't see any loose magnets or leaking goop from the stator
since two of my cylinders are still firing, am i safe to assume my timer base is probably ok? i would like to finish this job all at once
i tested the resistance coming from the timer base to the power packs (if i remember correctly) and all 4 connections gave me good resistance readings compared to what i read was recommended
engine is a late 1970's or maybe early 1980's evinrude 115. where do i find a good stator for this old of an engine?
edit- is this a good stator? or am i losing money by getting a "one size fits all years" stator?
http://www.ebay.com/itm/Johnson-Evin...25.m3641.l6368
I get 0 ohms
