No spark on 35
nimmor
We are dealing with a 1959 35 H.P. Johnson here. There is no spark at the plugs. Before I went trouble shooting the points and stuff I was wondering something. It orginaly had a hookup on the side for a wiring harness but I don't have the harness. I wired a solinoid and key switch onto the startor from another Johnson and the motor turns. Without the harness could the kill switch be engaged that is why I am not getting no spark? Also the shift lever on the outside of the motor is broken so I used a screwdriver to shift it until the propellor turned with no resistance which should be neutral right?
Paul Moir
Re: No spark on 35
Evening, RANimmo.<br /><br />The way the kill switch works is that it connects together two wires, neither of which are ground. If you look at the armature plate up underneath the flywheel, you'll find there's two black wires coming down from it. Those are the two. If either of those wires are grounded, the spark on one cylinder will stop. When you connect them together, sparks on both cylinders stop. <br />The long and the short of it is, if those wires are not connected to anything, you should get spark. <br />Watch those wires when you're running. There's about a -90v pulse on them that'll give you a bite if you touch it.<br /><br />The most common reason for you to loose spark because of cracked ignition coils. If the engine was outside in the weather, water will have migrated into the coils and shorted them out internally. Fortunetly, new ones are cheap and available. You can replace everything underneath the flywheel for $50 if you shop around.<br /><br />That sounds like neutral all right. Remember, you've got to turn the prop a bit when switching gears if it's not running.<br /><br />Good luck with it, and don't hesitate if you have any more questions!
