We are dealing with a 1959 35 H.P. Johnson here. There is no spark at the plugs. Before I went trouble shooting the points and stuff I was wondering something. It orginaly had a hookup on the side for a wiring harness but I don't have the harness. I wired a solinoid and key switch onto the startor from another Johnson and the motor turns. Without the harness could the kill switch be engaged that is why I am not getting no spark? Also the shift lever on the outside of the motor is broken so I used a screwdriver to shift it until the propellor turned with no resistance which should be neutral right?
