No spark 90hp nissan
Status
Not open for further replies.
gerald trentham
Took flywheel off to clean it and components underneath it. Put it back on and now have no spark. Any suggestions why?
Re: No spark 90hp nissan
Yes, I have ineed;
You have not read followed and unerstood the troubleshooting test that has been sent to you by ML.
By the way, stop fuzzing around go and buy a new used coil from iboats member PurkaAamo (cheap)
:love:
gerald trentham
Herra said:
Yes, I have ineed;
:love:
gerald trentham
I'm a musician not a boat mechanic so I guess I'll just take it and leave it with repair shop. I don't have the right tools and testing equiptment. It's just that they are so expensive and have 3 week waiting list before they even look at it. I don't understand why it would run before I took the flywheel off but won't even fire now. It's like I pulled the emergency shut off cord. All I wanted was to make it run better.
TOHATSU GURU
Gerald,
Did the flywheel key make it back into place when you placed the flywheel back onto the engine?
It is not difficult nor expensive to get it running you only have to concentrate fully on what you are doing, no special tools needed only one cheap multimeter, can be bought from almost anywhere. You don´t even need the multimeter if U do as I said before, buy the coil from PurkaAamo everything else might end up expensive especially if you send it to the repair shop.
Playboy
Did Gerald get his engine working, my is exallent now?
I was just about to sell it but now I feel different,
think i´m going to buy an third 90 hp,
this time an TLDI 90
Thank you all for your hepl!
TOHATSU GURU
Gerald,
There isn't any reason that that you would lose spark from taking the flywheel off and putting it back on again. It could just be fate, but here's the quick list of possibilites:
Blown fuse
Kill switch lanyard
Defective kill switch
Defective ignition switch
Loose or bad wire
Bad CD
Bad trigger(pulser) coil
Bad exicter coil
Bad ignition coil
If you managed to drop the flywheel there is a 1 out of 1000 chance you could have damaged the magnetic field...I've seen it twice in 40 years. But it's more likely that you blew the fuse or CD.
You need a manual for the test procedures for the ignition system. You can pick up an aftermarket one here on iboats or a factory original from any Nissan or Tohatsu dealer.
gerald trentham
TOHATSU said:
Gerald,
Blown fuse
Kill switch lanyard
Loose or bad wire
Bad CD
Bad exicter coil
Bad ignition coil
Bailman66
I pulled top spark plug wire off while motor was running great 90hp nissan outboard engine shut down immediately now wont start no spark on all 3 cylinders tilt and trim works and electric choke works..no spark on all 3 cylinders...need help
jbcurt00
Avoid posting to old Inactive topics and avoid duplicate posts.
You started and new topic already:
I was starting up my 90hp nissan for the first time in years it was running great and i called my self checking cylinders and pull the spark plug wire while it was running..engine shut down immediately and would not start,check for spark nothing on all 3cylinders checked fuse it was good tilt and trim and electric choke working need help thanx
Closed
Status
