No Regulator?
dmorano
I have a 1974 70ESL74M 70HP Johnson. Evidently some engines of that era did not have voltage regulators. Maybe because the output amperage is low (6 AMPS).
At any rate, the gauge pack on the boat (67 Alum Starcraft Jupiter ) no longer functioned so I replaced it with a Digital Volt indicator and a couple of switches.
At "cruising" speed I am showing 16.7 volts.
My intentions where to eventually install a radio, & fishfinder as a minimum. I am worried about over-voltage situations for these electronics. I have been looking on the net, but can't seem to fine any type of reto-fit unit as a plug and play to regulate the voltage output. I can find some DC-DC converters, but not knowing much about electronics.... Well it opens up a lot more questions. Questions that are above my knowledge level.
Anyone know any fixes for this?
F_R
Honorary Supreme Mariner
Give me a few minutes to examine the CDI book. I'm sure there is something in there. Later......
F_R
OK, I'm back. Combination rectifier/voltage regulator for your motor is CDI part number 193-3408. (non-regulated is 153-3408). Not sure if iboats has it listed yet, or not. Just pick up the phone and call. I'll bet they can get it if they don't have it on the shelf.
WernerF
Nice thing, a regulator in the rectifier case as a direct substitute. Must be new. Three years ago I had to use the old brick shaped type.
F_R
Yeah, I just looked and iboats doesn't have it listed yet. As I said, give them a call.
dmorano
Thank You, I will be checking this out. Probably a higher cost but certainly a easier install.
Vic.S
Lots of people are having trouble posting and/ or viewing pictures on various forums and browsers
I am having difficulty just posting anything on iBoats since th forum upgrade
dmorano
dmorano
Customer Support could not find on iBoats. They have the non-regulated 153 prefix but not the 193 regulated.
dmorano
Thanks again... especially F_R. for the part number.
Ordered from JMS Online out of Houston.
Will be hooking up wiring tomorrow in anticipation of regulated power.
