Silvertip
- Sep 22, 2003
- 28,772
Re: No power to my gauges
Don't trash the daisy chain for the simple reason that there is not enough room on the "A" terminal of the ignition switch to attach all of those individual wires that power each gauge. The daisy chain system is just fine and only one wire need be connected to the "A" terminal. That goes to the first gauge in the string. That terminal is then jumpered to the next gauge and so on. That's the way the boat was wired and it was done that for a reason (fewer long wires and a much neater installation).
using a known ground was just a test. Now you need to see where your missing the supply and fix it. You should have a separate power and ground to each item. trash the daisy chain and spiced stuff.
