wendellbee
Thread starter- Joined
- Sep 3, 2014
- 40
I have marine 460 the boat is a 93. Im assuming the engines are 89 or 90. while re-doing the heads ,cam,and timing chain on one of the engines i accidently turned on the battery switch. the coil was hanging over the crank and must've grounded out . I now have no power going to the ignition switch. I need to know what is the wiring scheme for the ignition. I do have power going to a solenoid near the starter , coming directly from the battery switch, but no power to the ignition switch on the dash. Thefuse leading to the swith is intact. I also do not see any 50 or 60 amp breaker near the motor. is there a schematic i can view or can someone explain how the wiring set up works. On a solenoid mounted near the starter there are 2 heavy wires, one from battery, ther other to starter, then there are 2 smaller wires. one is a starter interrupt for the gear shifter and the other i traced to the coil. i'm need to know which wire leads to the ignition switch
