diver_down
Thread starter- Joined
- Apr 19, 2009
- 64
long story short, end of last season i fried the stator; changed it (and the regulator), cleaned the carbs, drained the tank and put fresh gas, now the boat would not go faster than 1200-1300 rpm.
it starts right up, has spark in all cylinders, pumps water well, 80psi across the board compression, 6^ btdc spark at idle, the throttle advances as supposed to the carbs open but it just will not go. activating the choke changes nothing, if i push the throttle all the way it just dies instead of accelerating more.
on the muffs it will accelerate to 3000 if i raise the quick start (did not try more, don't want to screw it up).
any advice would be appreciated.
