no power (fuel) -- 66' 95hp o/b (inline 6)
vampirefish
Ok....so the saga continues :) Sorry for the long post. Took my boat out on the water last night for it's 1st 'trial run'...<br /><br />It took a while to start the engine and warm it up. Here's the problem... Once I got it to idle it would only idle (nuetral) with the throttle midway (sorry, no tach, no guages for reference) -- When I would push it all the way up, it would rev a little, but not what I would imagine (like it does out of the water). And forget trying to get it to idle with any less fuel than midway - it just died.<br /><br />I was 'finally' able to get it to not die when I put it in forward, but when pushing the throttle up, it would barely go...like it's being deprived of fuel. I was only able to get it in forward (without dieing) once.<br /><br />Here's what I do know:<br />1) It runs great out of water. When I push the throttle all the way (briefly), it revs up. After it's warmed up, it idles 'almost' at the lowest throttle position. It seems to idle fine.<br />2) Compression tests were all GOOD.<br />3) In the top carb (3 total), when I first got the engine running out of the water, fuel was spirting out. I knew the float was stuck. A mechanic told me that I could try to run it out of gas...that actually worked - no more fuel spitting out when it's running.<br />4) When I tilted the engine up last night, prepping to drive off, fuel was dripping from the carbs (not a lot, but enough to notice)... not good...<br />5) I realized this morning (whilst reading this forum) that I should have had the vent opened at least a little on my fuel tank..I had it shut tight.<br /><br />Solution(s):<br />1) So due to the float being stuck on the top carb (initally) and them dripping while the engine is tilted up... I'm sure I know the answer...have to rebuild my carbs, right? If I take it into a mechanic, should they test the fuel pump as well as all other areas that fuel is running..?<br /><br />2) Could it be as simple as the fuel tank not being vented to have caused it to run like that? Of course...I'm hoping this is the solution! ;)
vampirefish
Re: no power (fuel) -- 66' 95hp o/b (inline 6)
Thanks to Vlad D Impeller, he said (on a different post)...The fuel tank must be allowed to vent, meaning that air gets to replace the displaced fuel. If you close of the vent, you will encounter fuel starvation. <br /><br />soo.... maybe i should try to take her out again (with propper tank ventilation -- I'M SUCH AN IDIOT!!)...and see what happens. With the ability to actually run it ... running good fuel through it (with additive to clean carb) .. things may be ok.<br /><br />only problem... tilted engine = leaking fuel
Laddies
Banned
Fuel bowls leaking when a engine is tilted up is normal, just like tilting a glass of water on it's side
vampirefish
Laddies...anyway to avoid this...such as running it out of gas prior to travel...or is this just the way it is? THANKS!
Vlad D Impeller
Hi vf, if you suspect that the fuel pump is the culprit, replacing the diaphrams is a cinch, and the kit costs less than $15.00 ;)
vampirefish
Thanks all... by the way, Vlad...I gotta tell ya - I LOVE your username!
Vlad D Impeller
Originally posted by vampirefish:<br /> Thanks all... by the way, Vlad...I gotta tell ya - I LOVE your username!
Mmm! I'll bite :D
vampirefish
Well... with fuel tank properly vented, I'm <br />still not getting enough fuel to do anything on the water. Pop it into gear (forward or reverse) and it dies. Even in neutral it's barely holding on.<br /><br />Thinking it may be the carbs...<br /><br />Then a mechanic said it could be the reed blocks ?? -- now I'm scared. So I'm asking....should I just have a mechanic check to see if my carbs look dirty (obviously, having to take them apart...if they're not ...assume it's the reeds? Any other steps I can take (or have a mechanic take) prior to assuming this?<br /><br />RECAP: I do know that when my parents gave this boat to me (with engine) that it had been running great..until my kid brother cracked the lower unit. It sat for around 18mos... <br /><br />When I first got it running, fuel leaked from carb 1... so I ran it out of gas...which unstuck the float (at least no more leaking).<br /><br />Any advice would much be appreciated as I don't want to dump sooo much money into this...however LOVE the engine and know it's potential!
Vlad D Impeller
With the motor being laid up for about a year and a half, my bet is some varnishing has occured, the carbs would need to be taken off and rebuilt.
vampirefish
Yes, I agree...that's what I'm gonna do. I'll check back in once it's been to the doc! THANKS!
mums360
Up top you mention it ran great initially (out of the water) and I know you put fresh fuel in at the beginning. Other areas to check...<br />1. Fuel pump is functioning.<br />2. Fuel line is not blocked.<br />3. Fuel filter not blocked.<br />...
Clams Canino
Try cleaning/setting the carbs and checking the timing and synch per my post here on Iboats.<br /><br />If oyu suspect reed blocks after all that, try running double oil (25/1) and see if it helps at all..... If it does........the reed blocks are more suspect. A little extra idle and slightly richer idle mix can compensate a bit.<br /><br />-W
vampirefish
Quick update: Cleaned the carbs but that was not the problem. I tested it in the water and it still dies when put into gear (does idle better). My mechanic says it's a bad distributor (rotar). We'll see. I asked them to test it prior to cleaning the carbs (because I'm not a mechanic but was thinking it could be the carbs) -- they have yet to test it in the water - they just cleaned the carbs and called it good (didn't test it afterward - in the water). I was ready to just take my boat home (they charged me 2x the amount quoted) but they said they'd do me right. Wish me luck. :eek:
Elmer Fudge
I suspect the problem is with the fuel pump, replace the diaphrams and check valves, the kit costs around $15.00 or less in some places.<br />This is a job you can do by yourself, there are lots of folks on this forum to walk you through the procedure if you encounter any difficulty.<br />Give it a try :)
Jager1
I got the same problem with a Mariner 50 HP. It dies when I put in gear forward and backward. Carbs have been rebuilt, fuel pump diaphragm is new, new fuel line and tanks? Where are you with your problem? I am so frustrated...
vampirefish
They're still working on the distributor - and yes, it is frustrating! I'll reply back when I know more.
