no ignition or power tilt
BHT
I've got a 2003 Crestliner Sport Fish 1850 with a 115 Yamaha 4 stroke o/b. While I was installing the cranking battery, the boat cables "flipped" over onto the battery and the cable connectors briefly touched the battery terminals in reverse polarity. There was a small spark, but no "burning" smell. The in-line 2A fuse in the +ve line was blown, but the in-line 2A fuse in the -ve cable was not blown. After replacing the 2A fuse, I checked all the fuses in the fuse block under the dash and they all appeared to be ok. There was power to the lights, bilge pump, live well pump etc, but the tilt and ignition would not operate. Does anyone know if there is a main power breaker mounted on the motor under the cover and if so, where it might be?
tpcowfish
Re: no ignition or power tilt
You might want to try main forum, alot more traffic there, and good advice
BHT
Thanks for the advice. I'll do that.
