No fuel to bottom cylinder
MeHoBy
I have a 1974 Merc 500, 50hp, ser#3482234. Have had a real running and stalling problem this year. Did a link & sync, helped a little. Compression 125# on all 4 cyl. Good spark. Pulled the plugs, #1-3 all showed normal wear. #4 was dry and shiny as the day installed. Could it be a reed problem? Bottom carb feeds bottom cylders, right? #3 is firing. Any ideas would be appreciated.
Moody Blue
Re: No fuel to bottom cylinder
Sounds to me like you have water getting into the #4 cyl. The water steam cleans the plug and cyl. Lower crankseal failure or leaking exhaust cover permits water into the lower cyl's.
The bottom carb fees the #3 and #4 cyl so if #3 is getting fuel then #4 most likely is as well. Your motor has a distributor so most likely if one plug has spark, then they all will.
I've just pulled the powerhead on my 1971 Merc 800 for the same reason.
MeHoBy
Thanks Moody Blue. I'll check those 2 items
Laddies
Banned
A bad lower crank seal will effect #4 cyl, does it run on all 4 out of the water if so it's sucking exhaust by the seal.
MeHoBy
I never checked it on the muffs to see if it is affected. I'll change the seal anyway since I'm in this far
