no fuel?1998 evinrude e150jlecd
Daviet
Re: no fuel?1998 evinrude e150jlecd
Will it keep running if you keep squeezing the primer bulb? Maybe your fuel pump is defective.
rick derrick
yes it will keep running was just hoping it was not fuel pump looks like a $500 bill/never had any problems just wouldnt keep running last time out.
boobie
You can get repair kits for the fuel side only at Max Rules.com.
Check for air leaks in the fuel line. Air leaks will cause the OMS pump to lose prime.
rick derrick
going to order fuel pump kit,should i check anything else first?
