Re: No Compression
Jerry San Diego; the only time I have disagreed with dieselwalt is over this engine, and I only disagree a little. Please, Jerry, use a better grade of fuel, minimum 89 octane. Chapter 9, page 288 of the OMC manual reads " OMC recommends the use of unleaded or leaded gasoline with a minimum research octane number of 93 or anti-knock index number of 89. Otherwise the timing must be retarded..." and you can retard the timing, but, not enough on that engine; I know of what I speak. Modern electronic ignitions can retard to infinity or advance to tomorrow, but your breaker point system won't cut it. Just use a higher octane than 87 and if your tank now has 87 in it, get an octane booster and follow the directions. BTW, since no one knows when that head was rebuilt or who rebuilt it, it is possible it was done by an automotive mechanic with the wrong parts being used. That size valve has been used in other applications for years and years, and years...
