No Access to Fuel Tank Pick up 2003 Trophy
Status
Not open for further replies.
Donna Wittman
I have a 2003 21'7" trophy with a 150 mercury outboard. My problem is that the access panel in the splash well doesn't access fuel pick up lines to fuel tank. You can't get to them using the manufacturer's access panel in splash well.
Monterey10
Re: No Access to Fuel Tank Pick up 2003 Trophy
If you know where it is, you might have to cut a circular hole to access the sender. Then you can put in a hatch. Some hatches are press in, some are screw in. Some have diamond plate (appropriate in your case), some are smooth.
v6viking
Bringing this thread back to life...
Donna: Did you ever find a way to access the pickup lines? I'm having the same issue over here.
Thanks!
Status
