babylonlarry
Thread starter- Joined
- Jan 2, 2009
- 5
I just bought an old NS8B. Upon running it, there was no water coming out of the powerhead bottom outlet. If I blocked this outlet with my finger, the exhaust bubbles increased in the housing underwater. I took the lower end out to inspect the water pump and the pump, impeller and tube rubber seem good. I blew into the water tube and it passed air and water but not to the head outlet. I poured white vinegar into the tube and outlet hoping to unblock salt build up and am hoping that I can unblock it without taking the powerhead apart.
What kind of connection is there from the tube that runs up from the pump to the powerhead? It seems a bit loose.
I have a service manual that covers 2.5 thru 40c but not the NS8B. It has a M8B and a NS9.9B2
I followed the 9.9 disassembly and pulled the wrong pin in the shift rod (no biggie) but would like to know how to proceed if I need to do more dissassembly.
TIA for any help on this, Larry
