phercinger
Thread starter- Joined
- Apr 11, 2011
- 4
my first post...Ok got some questions. I took a diagram and made it into my own. I am totally redoing my boat. 1989 sea nymph w/70hp Johnson outboard/aluminum 17 ? ft. So here it is. Tell me if you think anything is wrong.
I also have some main questions I hope u experts can answer:
1) What kind of main switch do I need? I would like an on off for my accessory battery? please explain.
2) I plan on 3 batteries: 1 for motor start up, 1 for dash/gauges/radio/lights, and 1 for trolling motor. I have a marine battery charger that goes on the boat permanently and plugs into a house outlet before I go out on the water. My question is?..is there a boat alternator/recharger that runs off the motor when on the water? Is there something that will recharge my battery with the motor (70 Johnson) running?
3) I have a plan for 8 LED deck lights. Do I need a transformer for these? Or will they be fine if I hook them up through the fuse panel? I just don?t want to melt my wires.
4) What gauge wire do I run from the battery to the main on the breaker/fuse panel?
5) I want to repaint the outside?.aluminum?I have an airless sprayer. I need to go cheap but I need to make sure it will last. Please tell me your ideas for what kind of paint. Also explain the best process to use on aluminum?..
Thanks a lot for your input.
Pat
Pat
