newbie.....
phercinger
my first post...Ok got some questions. I took a diagram and made it into my own. I am totally redoing my boat. 1989 sea nymph w/70hp Johnson outboard/aluminum 17 ? ft. So here it is. Tell me if you think anything is wrong.
I also have some main questions I hope u experts can answer:
1) What kind of main switch do I need? I would like an on off for my accessory battery? please explain.
2) I plan on 3 batteries: 1 for motor start up, 1 for dash/gauges/radio/lights, and 1 for trolling motor. I have a marine battery charger that goes on the boat permanently and plugs into a house outlet before I go out on the water. My question is?..is there a boat alternator/recharger that runs off the motor when on the water? Is there something that will recharge my battery with the motor (70 Johnson) running?
3) I have a plan for 8 LED deck lights. Do I need a transformer for these? Or will they be fine if I hook them up through the fuse panel? I just don?t want to melt my wires.
4) What gauge wire do I run from the battery to the main on the breaker/fuse panel?
5) I want to repaint the outside?.aluminum?I have an airless sprayer. I need to go cheap but I need to make sure it will last. Please tell me your ideas for what kind of paint. Also explain the best process to use on aluminum?..
Thanks a lot for your input.
Pat
Shivam
Re: newbie.....
Hey hii, i am also new here!!!! dude hope you are enjoying your stay here!!!!!!!!
Boatist
Re: newbie.....
Welcome to the board, you can get a lot of good information here.
First a tip. Your subject should not be Newbie.
It should be: "Rewiring my boat and have some electrical questions."
The way it works is people are going to come here and check the forums they have interest in an look at the subject.
They will open the subjects they have interest in or knowledge about.
They will skip the subjects that do not make since or they have no interest in. No one opens every subject. Did you open every post when you came on?
Also Electrical wiring should not be in the same post or same forum as painting.
You should go back and edit your subject and post so you will get more people opening your post.
1: There are lots of types of switches. You can get a simple On/Off switch if that is what you want. Many use a switch that has two batteries connected positions are off /Battery 1/Both/ Battery 2.
Most setup where battery 1 is the starting battery and battery 2 is the house or accessory battery.
2:Most will have the motor, gauges, bilge pump, navigation lights, all on battery 1. Everything that came with the boat when it was new. A 70 hp Johnson will have some form of a charger or alternator. With 3 batteries many will get a charger that charges all 3 batteries at the same time or 3 banks.
3: Led lights do not need any transformer as they are DC. However LEDS need to be set up to run on 12 volts. Many you buy will be setup to run in a car or boat all you will need is a fuse.
Other leds will need the right size resistors to drop the 12 volts down to the voltage they need, around 2 volts.
4: Wire gauge needs to be large enough to supply all the current needed without getting hot or dropping too much voltage.
You will have to add up all the current needed for each battery and the distance from the battery. Then come back and people can help you. Depending on the size or your trolling will determine the wire gauge. Normally the same size as what is on the trolling motor or one size larger for long runs. The same thing for the Starting motor.
Radios VHF Marine I would suggest at least 12 Gage. If it is a high watt Stereo then it will have to be bigger to carry the current your amp needs.
Silvertip
Honorary Supreme Mariner
Re: newbie.....
A couple of issues I see are why do have the instruments and other accessories that were on the engine electrical system wired to a house battery. Keep in mind that you will end up with a ground problem because the gauges will be on the house system while the senders (fuel, temp, tach, etc) are on the engine system. Not a good idea at all as a problem in any of those system can draw current through the engine system ground and fry a bunch of wiring. As Boatist said, leave the stuff that was originally part of the boat as delivered as it was. There is no reason to separate it as those items draw very little current and besides, they turn off with the ignition switch.
You indicate you have three batteries. You cannot expect the very low output of the outboard to keep two batteries charged much less three -- especially when one of them will be a deeply discharged deep cycle for the troller. In my view you are overkilling this installation by at least one battery and a bunch of unnecessary wiring. At most, two batteries (one starting and one big deep cycle) and a dual battery switch or ACR is all you need. Wiring everything (engine and fuse panel feed) to the COM terminal on the switch. You now have full versatility to charge, start and run off either or both batteries as well as full isolation in whatever configuration you desire.
phercinger
Re: newbie.....
thanks for the tips. I will try to do some more research and specify on my questions. i will get back to you guys soon. thanks again.
