dakotajeep
Thread starter- Joined
- Mar 14, 2011
- 17
Gents/Ladies,
I just wanted to introduce myself. I am first time boat owner. I did run a marina in the FL panhandle for 4 years I know relatively little about boat repairs. Usually, if someone had an issue they had their mechanic come and work on it...mostly yachts and sport fish types.
Anyhow, again this is my first boat:
1987 Galaxie Boat Works 19' Open bow with a 230 hp 5.0 4V engine with an OMC outdrive.
The engine runs like a top. Starts up with no issues and ran perfect one the test run. The previous owner mentioned that the boat takes on water. He said that he had it on a sand bar and when he went to leave the boat had water in it. In the short term he had put silicone around the outdrive on the transom to slow the leak. While out on our test drive the bilge would spit out water from time to time but it did not run continuously. After the hour test run it had a small amount of water under the engien but nothing I would consider excessive...
Just curious if the seal for the outdrive to the transom is a hard repair better left to a boat mechanic or is it something I could do with minimal effort? Would I be better of installing a bilge with a float to keep the water from getting to high and just leave it or to have it properly repaired. I am fairly certain I should just get it fixed.
If there is anything else I should look at while I am prepping it for summer just let me know. I am a newbie for sure!
Thanks
Thad
Thanks
Thad
