Re: Newbie with gel coat ?
Slayer,
Here is a link with some great info on restoring/sanding/polishing/buffing, etc. gelcoat. Use it as you will. I got a lot of great info from it.
Restoring Gel Coat - fiberglassics.com
Thanks for the info. Funny cuz I actually was googling for some info on finishing up and found that.
Have had a little progress, and alot of frustration. Went out yesterday to sand some more. Started with DA sander, it decided to not work right( it's old, air powered, lost torque), so moved to HF polisher sander, worked well till decided not to turn back on after a break.( still not working) so then I went to a small palm sander to try and knock down some of the thicker areas and get a new sander later. That one started acting weird then " cluck" no more work from it. So i was a little ticked. Went to 4 local stores looking for a replacement. Couldn't find one. So pretty much a wasted day. Decided to buy/ change spark plugs and lower unit oil. Went to HF an hour away and found another sander.
This morning went to work. Went to sand some more with new sander. Kept getting gouges. Finally look at paper. Somehow I saw the 240 grit but grabbed the 80. Oh man things just aren't going my way. Spent rest of day today sanding, then covering spots where I went to much with sander. Not sure what I did this time but got mixtures off. Made up 1 cup of gel( just like I have been) and started covering spots. 1/2 way done and gel was kicking off. So I ended up with 1/2 cup of solid gel.
I have to work for the next 60 hrs. I am hoping my luck changes when I get back home.
Sorry for the sob story, just sharing the pit falls of small projects( haha)
