Re: Newbie questions/confirmation on a fiberglass boat restore
All in all the outside is not real bad looking at all.... Biggest things I saw was the hole in the keel,hole by transom plug and up at the bow..
Yeah, that was what I was thinking also. There's plenty of spots for chip and scratch repair with gelcoat, but nothing 'else' structurally big that I could see.
I'm estimating there's about 6' of keel I'll tear out and rebuild in two different spots. There's a spot about 1/2 way back that sounds funny (different than the spots I think are good) when I tap it that I'm going to replace because it's better safe than sorry....
The entire transom will be pulled out and replaced - I'm just waiting to get the rest of the hull fixed first. I hope that will help keep some rigidity as I'm doing all this stuff. Then, once the transom is replaced I'll get started on stringers, foam, floor, etc.
The hole in the bow will get fixed very well. I plan to heavily glass that area as it just seems weaker than I'd expect for supporting the front eyelet. So, I'll double up on the glass I put there just so it's well re-enforced.
