Grumpy Bear
Thread starter- Joined
- Aug 23, 2014
- 58
Below is what the CDI troubleshooting manual says I need to do to test ignition voltage on my 1974 Mercury 500 50hp. I made my own DVA to connect to my multimeter. However, as any good noob, I have questions!
(1) What setting should I put my multimeter on? DC 200? More? Less?
(2) So I have 2 leads, obviously, a black (-) and a red (+). When is says in the picture, for example, "WIRE: RED, READ TO: WHITE" What lead am I touching where? Are the wires all still connected to the switchbox or not?
(3) Finally, should the motor be started or should this be done while cranking only?
Thank you!
Thank you!
