Re: NEWBIE * disaster on first day*
The bolts are most likely seized in the plastic cover (maybe in the ali housing too, but we'll get to that).
Once you're checked it and it is confirmed leaking and needs replacing... put the housing in a stout vice, upside down, then take a small blow torch and a screwdriver and break up the cover and get it all off the bolts. Don't try a spanner at this stage. Once all the cover is gone, heat the bolts and the housing up to try and dry out any moisture in the threads. Once it's cooled down, use a long drift and a decent size hammer and give the bolts some sharp hits. We are trying to loosen them up as much as possible before using a spanner. You might like to throw a quart or so of penetrating oil on them too... and let it sit for a few weeks. (Just kidding, overnight would be enough.) The likelihood of breaking at least one of them is quite high, and breaking all 4 is very possible. If you manage to get one out, you have a good starting point. When we had our shop I had a template from a piece of 1/4" plate with the holes drilled. If we managed to get one bolt out and the others broke off, we'd screw the plate down with a new bolt and use that as a drilling guide. Trying to centre drill broken off stainless steel bolts in an inaccessible place inside an aluminium housing without a guide has about a 1 in 10,000 chance of going well... Most of the time the drill will slide straight off the top of the stud and into the ali housing... Not what you want. You're also going to need some LONG drills, or a drilling machine with a very small head and a long handle. Once you have them all out
lol
helicoil them! (should have been done in the factory :facepalm
At this point, about all that's left to say it, good luck.... and keep us posted.
Just one more thing.. Once you're done, replace the seal in the hole next to the cover. It's copped as much heat as the cover got.
Chris.......
