Gents,<br /><br />I have successfully managed to swap my water pump and lower unit on my Evrinrude 140. Some of you will undoubtedly remember the saga.<br /><br />All works fine and I get a strong stream of water.<br /><br />However, I have some concerns. When I first started the engine there was a loud whining noise. I put this down to the new rubbers on the pump impeller. Also, the engine didn't want to run at idle. It seemed to go slower and slower and then stall.<br /><br />When I took the boat out it still performed OK at high speed, but it had problems at crawl. The engine would just stall.<br /><br />I brought the boat back and ran it in a tank for 10 mins. It ran OK without any hickup and the whining noise decreased.<br /><br />Big question. Is it likely that a water pump couold have so much drag when new that it will affect the idle speed? Maybe I have done something wrong?<br /><br />The other issue to consider is that I replaced my gearbox with a friends. His power unit failed so he gave me the rest to use on my boat. No problems with the gearbox that I can tell with forward/reverse etc.<br /><br />Any help appreciated.<br /><br />NG
