D
DJ
Guest
Re: New water pump/gearbox affecting performance
On your poor performance issue-I believe you figured out your problem. You mentioned you had a LARGE fin on the old gearcase. Someone put that on there because the boat struggled to get on plane. Put it on the new gearcase.<br />As far as stalling on acceleration. Did it do this before? If not, did the engine sit for a while? I would do two things.<br />1. look for a vacuum leak-check ALL the little hoses around the carbs. These hoses are vacuum hoses. It could also be the source of your whistle or whine.<br />2. Clean combustion chambers by using OMC decarbonizer.
