reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I have been running an older 3HP Minnkota transom mount trolling motor since about 1989. The boat is a standard 14' modified V jon boat. I run a single group 27 AC Delco deep cycle battery. I got the chance to pick up a new Riptide series 55lb thrust saltwater rated trolling motor, my thinking is that I can now venture into brackish and saltwater a bit. I first hung this motor on a smaller 12' V hull to give it a try, I borrowed the battery from the other boat. On the first time out, I killed the battery in less than 3 hours. Then again in even less time a week later.
To make the comparison fair, I put the Riptide 55# motor on the other boat and tried again, it did the same and killed the battery. The next day, I went back to the 3Hp and went all day on that motor, barely draining the battery at all.
Thinking that the new motor just draws more juice, I added a second new battery in series, this added only two hours of use. Fed up with the motor, I returned it and got another one. But the same thing continues. The problem is, the 3HP is a much faster motor with a lot more pull overall. It was pretty much my impression that this was a pretty close match to the old 3HP motor but in a sealed version? So far I'm pretty disappointed. There have been weekends where I ran my 3HP all weekend and never came close to draining the battery. This new motor does it in only a few hours. The 3hp uses an older style, more conventional prop, while the newer motor has a narrow blade weedless prop. On full power, they both move nicely, but the RT55 creates a huge prop wash or whirlpool behind the boat no matter how high or low its mounted. The 3HP makes far less water disturbance and the boat moves right out. I think the prop has some to do with it but not all.
The RT55 makes a lot of heat too, where as the 3HP doesn't. Even the control head on the RT55 gets warm.
For comparison reasons, I borrowed an Endura 40 from a buddy that tells me he gets about 4 hours at part throttle, but it will kill a pair of group 24 batteries in less than 3 hours at full power.
The Endura 40 ran only 3 hours on my boat, mostly at full speed. Any less and the boat would barely move.
We are only allowed electric motors here in non tidal waters, so the trolling motor is the only propulsion other than a pair of paddles.
My boat weighs in at about 750lbs with me, the motor, battery and tackle. Other than that its a bare aluminum boat. The 3HP has never completely killed the battery, it's never even come close. I also have an older 65T, which is only about 28lb thrust, that too will never tax the battery in anyway and I can run full power all day or more.
The Riptide sells for $499 at local shops, I got it for just over $300, but even at that price, which is still far more than what the old 3hp cost back then, I am very disappointed. I plan to just take the Riptide back and give up at this point, I picked up a second 3HP as a spare, it runs good too, and I have several other older motors which all run great. I just can't figure out whats up with these newer motors? Are they all this hard on the batteries? Did they change something I don't know about?
