fireman358
Thread starter- Joined
- May 12, 2009
- 1
Hello all,
I have a 1989 2 stroke 125 hp force outboard motor that came on 19 ft bayliner that i bought for $500 from a co-worker. Here is my problem, becides that i bought a 500 $ boat, The power head is shot so i ordered one. It was removed prior to my buying the boat. I believe i have all the other parts, but i have some questions.
1) The section between the powerhead and lower unit has the cover taken off i believe its called the shaft cover or something, does that have a gasket too it or is it just a bolt on. if it does whats that section called and wheres the best place in ct to get one.
2) When I turn the prop by hand in the rev.direction there is a ticking noise I hear. Is that normal? If not what do you think it might be?
3) Are there any tips i should know about this motor or tips in general?
4) As for a battery, what type and or turn over power should be used if it matters? Will any decent marine battery work?
5) I also heard that ther is a led additive i should be mixing with the fuel. Should i use it or does it not madder. if so why?
6) When changin the gear oil in the lower end, do i need the pump to fill it reversed or can it be done without it.
7) This boat has not ran in 2 years should i change the cooling impeller or only if it isnt spitting whater when it starts.( if it ever does)
Thanks for all your help. by the way i cant spell for my life sorry for the errors
