New Solenoid, Outboard still clicks. Gas issue maybe?
BassBoatNewbie
Just replaced the solenoid for a clicking & voltage problem. Fixed voltage issue but I'm still hearing a clicking noise. Now, I'm not a mechanically inclined guy by any means (I know nothing about vehicles/boats other than the basics) so bare with me here. But here's a stupid question: Could the Clicking (Sounds like Primer Solenoid) be from lack of gas? Because I noticed late this evening that I was almost completely out?
F_R
Honorary Supreme Mariner
Absolutely no reasonable connection between the two, other that either can keep the boat from going out.
The clicking is an easy fix. Get a multimeter and check the voltages out. If you don't know how, either learn or get somebody to help you. Tons of stuff have been written here on the subject. Even easier way is disconnect the battery cables and clean them shiny bright and reassemble tightly. Don't just look at them, get all the layer of non-conductive corrosion off them. That alone, will fix 90% of the cases of this type. Oh, and have the battery load tested. Many places will do it free.
The empty tank is even easier. Nobody has to tell you how to fix that. (Just kidding, don't take it too seriously).
poconojoe
Problem is electrical not gas. Could be dirty connections as F_R mentioned or your battery is no good. As F_R mentioned, take some voltage readings. Report your results here and someone will help you.
Crosbyman
clicking results from the momentary application of voltage or insufficient voltage to the selenoid. lets presume your battery is good and charged
​you do not indicate when this happens (circumstances) momentary clicks, constant slow clicks ....motorboating clicks (fast and furious)
is it while sitting still or underway with boat vibrations ???
the normal activation of the selenoid comes from the starting key switch and its wire conductor while in START position
it could be a bad switch (loose contact or frayed wires touching a +12 directly the START wire,
the start conductor could be frayed or crossed over to a +12 by vibrations anywhere between the key and the selenoid !
check for loose frayed connections along all the circuitry . wack the start key assembly to cause vibrations and listen to the selenoid see it clicks (responds to wacks on the key assembly)
try disconnecting the start lead on the selenoid to confirm the source of inappropriate +12 is coming from the wire itself (read with a voltmeter but short hits may be to fast to be measured especially with digital meters use a needle meter is my preference because needle meter don't have to do signal samplings before deciding to display a result.
Probably rare but it could be internal defects inside the selenoid no external cause can be found found.
if the start wire is disconnected and clicking still occurs.... I would swap in a new selenoid
btw I hope you do mean the clicks are internal to the selenoid...does the starter activate or are clicks to fast.
