New problem...
mmuutts
1984 Johnson 25
Mod# j25elcrs Ser# e6005425
On the stand and in the tank.
I can squart a little fuel in the carb and she fires right up...Until fuel runs out.
Carb does not seem to be getting any fuel. I squeez the Blub and it gets tight and stays tight.
Any help would be awesome! *This is from a different post..
This post:
Now...When I hook up the remote control It turns over fine and I can see fuel comes/leaks out the Elec primer etc...so I know thats working...but...now I have no spark..lol...one thing or another...
Any help/thoughts would be great! Thanks
mmuutts
Re: New problem...
Any toughts? I guessing carb problem for the first problem....I just had a thought on the second problem...does the control have a kill switch...you know the ones with the little red cord that pull out...Would that keep the plugs from firing but still let the motor turn over?
thanks for any and all help or ideas...
eclark53520
Re: New problem...
First problem, carbs need to be rebuilt no doubt.
Second problem, plugs not firing, yeah usually kill switches do not kill power to the starter. They kill the ignition which would cause the engine to turn over, but not produce spark.
mmuutts
Re: New problem...
OK..Cool...I will order a new kill switch thingy...And a rebuild ket for the carb...Thanks!
