New power pack not grounding
gsyfishy
88 40hp johnson, new power pack installed yet when key is turned off motor keeps running. New pack seems to not be grounding out.
Xcusme
Re: New power pack not grounding
Have you tested and verified an Open and Shorted action of the kill circuit at the switch?
Joe Reeves
To test the powerpack itself, ground out the black/yellow wire from the powerpack to the powerhead. That should ground out the ignition immediately.
The kill circuit is: BLACK ground wire from powerhead to powerpack. BLACK/YELLOW wire from powerpack to one "M" terminal of ignition switch. BLACK wire from other "M" terminal of ignition switch to ground.
Check the continuity of the above circuit with an ohm meter.
