mikemo1964
- Mar 5, 2010
- 10
Hello and thanks for reading. I just purchased a 1995 Maxum 1700XR and had some maintenance questions I was hoping to get advice on. The boat has been garage kept since new and it shows. I didn't want a project so I waited for something in my price range that had been well cared for.
1) I can't keep this boat in my garage (it won't fit). I plan on keeping it on the side of the house under a 10x20 shelter (steel poles and canvas/plastic top). I don't know if I should also cover the boat with a tight fitting cover while it is under the shelter. If I cover it, I'm worried about mildew (I'm in steamy Florida). If I don't cover it, I'm worried about the filth that will make its way inside, along with those pesky wasps that seem to want to build nests everywhere. Maybe I can cover it and provide some sort of ventilation?
2) How do you cleain the inside of the boat? The floor is carpeted and the seats are vinyl. Can I just hose off the inside of the boat and let the water drain out the back? Will it take forever for the carpet to dry if I do that?
3) The boat has a built in fuel tank, that according to the manual is 22 gallons. During our sea trial, the fuel gauge bounced around quite a bit. He said that the fuel was fairly low. Since it is a two stroke motor, what is the best way to mix the fuel and fill the tank, while making sure the mixture is correct and not overfilling the tank (which according the the manual is a no-no).
4) The outboard is a 1996 Force 120 two stroke. The hour meter on the boat shows about 250 hours. The owner had maintenance records that show the motor was tuned up and the bottom end had been resealed and re-lubed two years ago, and the compression was 135psi across all four cylinders. I know that the Force outboards don't have the best reputation, but I wanted to know what I could do to keep this one running with the fewest problems.
Here's a picture:
Thanks again!
Mike M.
Here's a picture:
Thanks again!
Mike M.
